carbondaleQ »
https://forums.nicoclub.com/carbondaleq-u37435.html
Sat Feb 18, 2006 5:52 am
Hey guys, Ive been on this site for years but old username failed... Q recently developed a strong vibration above 3K. (140k miles on her) Same in neutral or driving (not driveshaft/transmission) replaced plugs 5k ago, injectors replaced 3 years ago and are in spec, TB is clean, MAF connector is good. Motor mounts "seem" OK with little engine vibration when revving. Only recent service was waterpump--and the pulley does vibrate/oscillate more than old one.
Pulled ECU codes and showed 45 and 34. Injector leak and knock sensors. I replaced #1 injector (was at 18 ohms) and drove the car; same problem. But this time the code is 55 (no problems). I'm thinking TC or some injection issue. Car idles fine (no hunting) but does have slight tremor. Good power but shakes. Haven't done PB test or consult.
Thanks for any ideas!
Sandor
