goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Sat Mar 04, 2006 8:33 pm
I'm still having major problems with a rough running engine. Got about 9 mpg on the last tank of gas (Usually get 15) and the smell of raw gas is present. I've quit driving her for now. Runs better at high rpms but you can still feel the roughness. I took it in for a BG flush, thinking I may have plugged injectors but no improvement. I also swapped in a good MAF and no change. Plugs and CAS connector cleaning helped but still running rough.
So things are pointing more and more towards injectors. The shop measured the fuel pressure at 34 psi. I failed to ask if they plugged into the line past the filter and turned on the pump only, or teed into the line and checked with the engine running. What is the correct procedure and what kind of pressures should I be looking for? I thought I read that the pressure should be in the mid-40's so 34 psi might mean something. Based on your responses I'm going to go buy the setup tomorrow so I can check it myself .
Another thing I'm confused with is the term "leaky injectors". Are they not holding pressure internally? Leaking internally from inlet to outlet? Or does it mean that the small o-ring is not seated and the gas is pouring in through the fuel rail. There are no external leaks from the large o-rings and no hose leaks either. Or, does the injector fail electrically in the open position and let gas pour in.
Finally, what injectors can be taken out easily without removing or grinding the plenum? I ordered some from Joe and might get lucky and find the one that's leaking.
I guess I'm asking these questions because I am having a hard time understanding why only one injector with a reading of 27 would cause all these problems. Something else must have gone wrong to cause my current issues.
I've got her parked for a while since I was in an accident last week and she's going to the body shop on Thursday ($3700). I don't want anyone to see her all banged up. I'm going to listen to the injectors with a long screwdriver tomorrow and check the fuel pressures.
Looking forward to your input to help me with what I need to know to pass Fuel Injectors 101.
