94 Z32 Water Pump/Timing belt Replacement
Durbdog97
Car: 1994 Nissan 300zx 2Dr Coupe.
SO about a week and a half ago my water pump went out, A couple days ago I went and tore down the engine bay. So far I got the Radiator, Fan and all the belts off except for the Timing belt. What size alan key is used to take the covers off? And How hard it is to take the Crank pulley off without a puller? Or would it be better to just rent a puller? Anything else I need to replace while doing this? Accessory belts, tensioner?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Durbdog97
So the bolts on the timing belt cover are stripped, any ideas to help get them out so I can get my Z back on the road quick?
NolimitZ32
extractor drivers
