dnudelman »
https://forums.nicoclub.com/dnudelman-u222826.html
Sun Dec 29, 2013 4:51 pm
Thanks,
I've done a pretty good seach on this site and it appears that the Fail Safe reset is either
a. Look for a blown fuse, both fuse boxes and fusible links
b. Turn key off for 3 seconds.
I have tried both, no success. In fact I pulled out every fuse and examined it.
Current status
Transmission will not shift into 4th gear. 60mph, 4000 rpm/ In Drive, take foot off gas, no engine braking
Move selector to 3 and I have engine braking
from a full stop, you can manually shift into 1st and 2nd.
AT check self diagnosis - No codes.
I have a brand new ECU Talk cable and ECUTalk, but sadly doesn't appear to do transmission diagnostics
I am pulling ECU codes 34 Knock Sensor and 51 Injectors. Inject5 is bad with 2K ohms, one of the knock sensors has very little resistance.
I have a plan to do injectors, knock sensors, plugs, gaskets, hoses, pcv etc but want to determine what is the transmission problem first.
Any more suggestions appreciated.
