94 TX cluster problem help please
300zdett
Car: 300zx tt slammed
Well the speedometer was not working . So I decided I would remove the cluster to see if the connections were loose. Disconnected all the connectors . Connected them back up and now nothing works boost needle sitting at 14 psi, fuel gauge on full . Temp is low. Disconnected everything again cleaned off the connectors and still same thing ......
What is wrong now ?????
ZL8NING
Car: 1993 300zx 2+2
I hope you did all that with the battery disconnected. Anyway, you might have blown a fuse. Check them out.
