I'm not sure that the TCU is different between CA/FED/TC/A. I think it's only the ECU that changes. To my knowledge there are two 1993 TCUs that will work. They both come only from the 1993 model year and have part numbers of 31036-64U20 and 31036-64U75. I think the 64U75 is the remanned unit that would have been installed with transmission replacements in the late 1990s and 60U20 is the factory one.
It's probably a good idea to have the 93 ECU with your TCU - some members have reported a problems at redline due to the TCU hitting the rev limiter. I've used both combinations, and it really seems a little smoother on the 1->2 shift but I can't tell a huge difference.
I happen to have an extra set (ECU and TCU) on my desk... email me back channel at
[email protected] if you're interested. They're from a standard (no Active, no HICAS, no TCS) federal Q.
Heath
