SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Wed Sep 07, 2005 6:25 pm
Z brake front swap is simple if you know where to get parts.
Auto Parts Stores and any brake shop can get you what you need.
Before you do (for example) the 30mm TT aluminum calipers, make sure you have wheels that will clear the larger caliper.
Use TT calipers, hoses, rotors.
Some people redrill the TT rotor to 4lug. Buy 5lug aftermarket hubs instead.
Some people also decide to keep their stock 240sx master cylinder in place. I chose the 1-1/16" nabco M/C. If you get this M/C, there is no need to drill out the fitting from your 240sx M/C and install it into the new M/C.Finding parts is so simple. Several sponsors offer various kits.If you order from a parts house simply ask for m/c, calipers, hoses, and rotors for a '90 300ZX TT. If you want, Phase2 offers stainless conversion lines which are hot.
