'94 s13 overheating, need help
rhatmonkey
Car: Nissan 240SX Convertible
ok, so i bought this car about 3 months ago, recently (about a month) i found out that he was running the car without a thermostat. well, figuring the car needed the thermostat i installed one. The car ran decent for a while, the temp needle stayed in the middle but on occasion it got close to H but then came back to the middle. I've been working on bleeding it but having no luck. Anyway, about a week ago the hose that connects the radiator to the thermostat housing came off and i lost all my coolant, i found this out when the car exceeded the H mark and i pulled over. Turns out the OEM clamp that holds that hose on broke, so i bought a new one, put it on, re-filled with coolant, and rebled.
Here's where the problem comes in, now when i drive, if i'm idling (like at a red light, stopped in traffic, etc) the needle starts to make its way from the middle to the H but doesn't come back down unless i either rev the engine (4k rpm or so) or take off from that stop.
Asside from a rare rough start (car shaking and all that, lasts for a minuteish) there are no other symptoms. As i mentioned i've replaced the thermostat and have plenty of coolant. I think its the waterpump but there is no odd sound comming from it...
Does anyone have any idea what else it could be?
rhatmonkey
turns out the head gasket is blown...
