'94 Q45t. Performance Mod advice.
konatown
Car: 1994 Infiniti Q45t
2010 Genesis Coupe
I'm bored with 296ft-lb of torque.So I'd like to supercharger this engine. Any ideas, thoughts, suggestions?The engine is past the break in perion, 136k. New injectors, engine computer just reflashed.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Elwesso has some info on a supercharger setup if you have the cash. I'm sure he'll chime in shortly. I have spoken to ststurbo.com about a rear mounted turbo setup and they told me they could put together a univeral kit and I'd have to fabricate the plumbing and some other things.
A search should pull up a few threads on superchargers and turbos as it's been discussed many times.
Get it done and you'll be the only one on here that's ever forked over the cash to get it done! You would be kewl
konatown
2010 Genesis Coupe
Money may be a problem, looking to spend around 5k on the setup...i can fabricate the plumbing with no problem.. friend and i built a pole barn thats loaded with equipment.
Just finished our mudslingin' Wagoneer with a 454 big block, we custom fabricated our exhaust
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Noticed your from evansville... right now im in the opposite end of the state (angola), but am from anderson mostly.....
if you wanted to fab up some headers or something, id be glad to help...
konatown
2010 Genesis Coupe
Thanks for the offer! And right back at you
