sijoko »
https://forums.nicoclub.com/sijoko-u297.html
Wed Mar 05, 2008 12:09 pm
I pulled my trans with the occasional help of my wife. It can be done but it will take you a bit of time.
I had to lower the engine subframe and drop the rear of the trans to get to the top bellhousing bolts. Once I got access to them, my impact gun would not budge them. I had to use a breaker bar with a super long iron pipe for leverage. Even then, it was hard to loosen the bolts.
Picture me underneath the car holding the breaker bar from slipping off while I push on the pipe as hard as I can and my wife standing on the side of the car, pulling on the iron pipe with all her strength. Finally, there was a loud clank and I thought I had broken the bolt. But it worked. Anyway, don't let me little story discourage you. Just be ready for some huffing and puffing.
If I had to do it again, I would probably just drop the engine and then separate the trans or just get the most powerful 3/4" impact gun on the planet.
