I just check the fluid, almost gone. Where can I get it?elwesso wrote:The odometers go out sometimes on Qs. not really common but sometimes they do. Sometimes they come back. If you want just swap instrument clusters.
Check your active suspension codes, i wonder if you have low fluid or something.
And if it's almost gone, there's a reason - find the leak! That fluid is expensive.stojakovic wrote:I just check the fluid, almost gone. Where can I get it?
What year is your Q? I have a 95' cluster for sale.elwesso wrote:The odometers go out sometimes on Qs. not really common but sometimes they do. Sometimes they come back. If you want just swap instrument clusters.
Is this what you bought?stojakovic wrote:Got the fluid. Filled 1.5 bottle and I can feel some effect... The car bounces more 'predictable'...
However, the ACTSUS light is still on.
Hope take several days to revive the ACTSUS.
Yes, MVO is Marvel Mystery Oil.stojakovic wrote:I found there is some leakage on my active fluid system. I remember someone used MMO to fix it. What is MMO?
I guess it is Marvel Mystery Oil, right?
