94 q45a misfire in one of the cylinders
TmaCular
Car: 1994 Q45 150k
hey guys i got a 94 q45a that just had some work done missing pins on my ecm were replaced so my fuel pump would turn on. my mechanic told me there is a misfire occasionally in one of the cylinders. he also said its needs plugs. so ? is replacing coils and plugs would that stop it or r there others possibillities it could be. im also trying to find a mechanic in michigan that can help me as well as price for those things and recommended parts.
thanks a bunch
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
If your mechanic did a powerbalence test ask him to tell you what cylinder is mis firing. From that you can replace the spark plugs. If the problem persists then take the coil from the cylinder that is misfiring and swap it with another known good cylinder. If the problem has moved to the known good cylinder than you know that it is a bad coil. Or you can just buy one coil and start replacing one by one to weed to the bad cylinder.
superuber
Welcome, First off what maintenance has been done? Also current mileage?If you are behind on your service get uot your money!
goody90q45
Car: 1992 Infiniti Q45 (sold)
Ohm your injectors (and knock sensors). A 10 minute DIY job with a voltmeter.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Best prices on parts usually is through Joe at http://infinitipartsusa.com/Also great professional service.
TmaCular
Car: 1994 Q45 150k
superuber wrote:Welcome, First off what maintenance has been done? Also current mileage?If you are behind on your service get uot your money!
not to much maintenance i did a conversion swap on the hydraulic suspension cause it was broke. regular oil changes with ext. perf. mobil one. other than that i got the car last year for 500 cause the suspension and fixed it for cheap so it was a steal. it has 118k on it. just recently i had 2 pins fixed on my computer and another six were loose. now im going into a tune up and looking to know all i should do.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No other fluids? No filters?
You will learn a lot form reading the old posts.
