Follow-up...
Here it is, ten months later... I've been living with that 'shudder' all this time.
Back in September, I had my mechanic check the rotors and pads... all seemed ok. He even switched the two front rotors - no change in behavior.
Thanks to TexasOil, we replaced the two front accumulators with freshly charged ones... it improved the ride - but the damned shudder was still present.
Stumped. I drove the car all winter and spring and got very good at adjusting brake pedal pressure in creative ways to minimize the 'shudder'.
Took the car back to my mechanic earlier this week with instructions to keep the car until he could find the source of the vibration... I even gave him a caliper to use for the front if he wanted to swap that out... along with two new rotors.
Lo and behold, he called a few hours later and said he found the problem... something he missed back in September - something he should have caught: some crud was stuck between the rotor and the hub. After cleaning up the hub and replacing the rotor... the shudder was gone. With the charged accumulators and smooth brakes, the front end feels like new (which is damned good on a Q45a)!
Just goes to show... cleanliness IS next to godliness!
- michael
'94 Q45a w/no shudder
'98 SL500 '98 Durnago 4X4 '83 F250 w/plow '80 Spitfire
