3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sat Sep 24, 2016 9:12 am
yep, 90-93 water pump different from 94-96.
you'd think they would notice when reinstalling the belts.
your ps pump is also the active pump.
the wp belt also drives the combi pump.
is your active still (at least semi-) active? if yours has been converted, unless done properly many times the combi pump seizes with time due to insufficient lube of the active segment of the pump.
water pump bearings (is it a genuine nissan part--PUMP- INF #21010-67U28?) also sometimes squeal.
idler pulleys also can get bad bearings (what is the pedigree of that part?)
beyond that--the belts on these cars do want to squeal. suggest OEM (BELT, P/S&WP INF#11950-60US5VW) because they have a felt on them that helps reduce the squeal. make sure properly tightened as it will stretch after an hour or so of operation.
