94 Q45 Wont Start due to Security Armed
HotAugustKat
Car: 94 Infiniti Q45
This Q 45 has been sitting for 6 months because of Starter not engaging due to loose contact. They banged on it to start & drive for awhile. I had it towed to my house now here I go again....
First removed battery and put on charger then got under car to view Starter. On the Starter Selenoid was a broken loose cooper fitting that holds the thick wire from the starter. I replaced fitting and crimped the wire securely in it along with another thin wire that was also off. Put it all back on the selenoid bolt then tighten the nut. Maybe this will do it. Put the charged battery back in.Also some missing fuses. Well the car turned over but the battery did not hold charge so it wasnt enough. Then put a good charged battery in and nothing due to the security light flashing. Tried to disarm Security by unlocking doors with ignition key and unlocking trunk but still nothing. Please I need help with my daughters car she is driving me more crazy than her car. Desperate thankyou
HotAugustKat
Rex
Car: None
When you attempt to disable security with door/trunk lock mechanism, is the hood open or closed?
You might want to try the passenger door lock, as the drivers one could be worn from use and (possibly) cheap non-OEM key use.
HotAugustKat
Thank you for responding greatly appreciated. Yes I had the hood down passenger door unlocked, drivers door unlocked trunk and nothing ... Today rehook the battery maybe something cleared or reset. Hood shut trunk shut doors shut and hey security light stopped
blinking but still no instrument lights now attempting to see if it will start or turn over or engage anything... Nothing but a faint little click down by glove box (passenger side) soo....
Could it possibly be starter relay had daughter pick one up at Napa yesterday but of course it was not the starter relay just some other blue relay. Ideas?
Thank you again very much
HotAugustKat
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
The click noise from the passenger side kick panel area you are hearing is the ECU relay clicking. The starter relay is located next to the black box that is circled in red:
https://picasaweb.google.com/lh/photo/N ... directlink
The starter relay is the blue squre by the shock tower.
HotAugustKat
Thankyou for your quick responses and your help and time. Yes I know where the Starter Relay is, but could this be my no start no turn over no nothing engaging problem?
HotAugustKat
HotAugustKat
Thank You I had my daughter pick up a Starter Relay up yesterday. Well, Napa gave her the wrong one soo....I will send her back if you think that might be problem. Thankyou very much for evertything.
HotAugustKat
Infinitiguy19
For the time being hit the starter relay with a rubber mallet or a hammer (GENTLY!) and see fit he car starts up. Crank while hitting the relay.
HotAugustKat
Ok will try that again thankyou very much should I also hold down the hood button so the car will think the hood is down while gently hitting starter relay and turning key over all sametime?
HotAugustKat
Infinitiguy19
You can disconnect it if your gentle with the connector or put some electrical tape over it.
HotAugustKat
Again thank you for all you have done as far as all your quick responses and your time along with all your helpful answers. Well I tried the above and still nothing......so if you feel like hangin in there with me I will be forever thankful and if not I will understand. Im thinking of what to try next...hum Thanks again
HotAugustKat
Rex
Car: None
Assuming you've gotten "past" the security system issue, can you put a voltmeter on the battery and see what it reads with no load and again while trying to start the car? Also, it would be interesting to see what numbers you get at the starter itself.
HotAugustKat
I dont have anything like that but I will ask my brother if I can use his but I dont really know how.
Im just old ways just tools no equip my brother has all that but been ill for a been ill for awhile I will do it and let u know.
Thank you oh ya im assuming I got past security but maybe not because why don t1 I at least hear the fuel pump when I turn on key?
HotAugustKat
Rex
Car: None
Can you get the alarm to sound/flash the lights? Maybe the alarm doesn't really work??
A voltmeter isn't anything fancy, a "basic" digital one should run about $20 from Radio Shack.
Also, make sure you check the fuses both under the dash & hood.
This may help as you go
http://www.nicoclub.com/FSM/Q45/1994_Q45/
HotAugustKat
Thank You, Alarm doesnt sound it flashes on & off until I guess disarm it by unlocking drivers door with key and unlocking passenger door and trunk with key then shut trunk and tape down
hood stem to think hood closed. Close all doors then security light was still flashing until I ran a wire from under the security fuse located under dash to an empty fuse spot next to it. I did that only because my daughter said thats how it always was ever since she got the car? Well the wire made the security stop flashing, but still nothing. Yes my brother has a voltmeter. I downloaded all FSM last night trying to read & comprehend diagrams. Thank you oh they just came and took back the battery I was using SH** HotAugustKat
HotAugustKat
HotAugustKat
Thank You, Although Security Light stops flashing when I do this process is it really disarmed? Because when the START position of key ignition is turned shouldnt this cause a signal to be sent to ECU. .should I at least hear the fuel pump for a few seconds when I turn key in ignition?? Or something? or instrument lights go on? So.....
Maybe Security is not disarmed after all....Thank youall for everything please continue to help me it is much needed & appreciated.
HotAugustKat
Rex
Car: None
It's been a few years since I drove a Q45, but I don't recall being able to hear the pump (a good pump anyways).
Try opening the trunk and listening for the pump. Maybe even try it both with & without the fuel pump fuse pulled.
HotAugustKat
Thankyou will do and let you know along with those Voltmeter readings as soon as I get another battery.
HotAugustKat
