soldierboy wrote:Also it reads "transmission malfunction" but it still feels normal. If anyone can help me that would be great.
Hopefully the "Transmission Malfunction" light is only on at startup and goes off after a few seconds. There is a self-diagnosis in the transmission section of the FSM. It's very easy to do and should lead you to the problem. Sorry I can't find the link to the FSM download but it's here on the NICO website. I get the occasional message but it always clears and the transmission shifts like a dream. You're probably due for a transmission flush and filter change to extend its life.
DrewQ45 wrote: Clean your battery terminals first of all. If not that, it does sound like your starter.
Drew is correct about checking (and cleaning) the battery terminals first. Are both terminal clamps tight? Do they rotate on the battery post even though they're tight? I had similar problems to yours and ended up replacing the clamps.
