Exactly why one always reads the FSM for accurate information!blacksrjdm wrote: As long as you clean off the mating surfaces sufficiently, then there should be no need for any silcone gasket maker (rtv).
I should add that I prefer replcing the metal capped rubber VCreatiners between the nuts and the VC. Mine are deformed and hard. New, they are quite supple and must contribute to proper torquing of the head bolts.maxnix wrote:I use Nissan red RTV where specified in the FSM. Read it, then look at the threads.
