94 Q45 valve cover removal - passenger side
CalQ45
Car: 1994 Infiniti Q45a
Do I have to remove a metal bracket (attached to engine block) that holds electrical connectors? It is attached with two 14mm screws. They seem to be very firm, hard to loosen.
Raxephon
Car: '04 RX8...for the moment...
If you're talking about the bracket between intake manifolds #6 & 8, (see picture), then no.
Check out http://www.q45.org
Lots of info, read religiously.
(Picture taken from http://www.q45.org for illustrative purposes only)
CalQ45
Thank you for responding. Yes, that's what I meant. I removed plenum. This bracket sits between injectors 6 & 8. I probably will have to remove electrical connectors to get accsess to valve cover screw. Do I need to remove a cover over spark plugs first? I intend to replace spark plugs. Should I replace the valve cover gasket first, and then spark plugs? Going through other postings I found out that the lower valve cover screw by the fire wall can be accessed from underneath the car.
Today I replaced injectors. Valve covers. spark plugs and KS are next. By the way it is a Q45a with TCS so perhaps I have more hoses and wires. Any tips will help.
Thanks again.
Raxephon
CalQ45 wrote:Any tips will help.
Looks like you don't have a FSM.
I have one in PDF form that you can have.
Hit me up on AIM/Yahoo Messenger or email me.
Email: [email protected] AIM/Yahoo Mess.: anlasak
Modified by anlasak at 10:39 AM 10/15/2005
Modified by anlasak at 10:42 AM 10/15/2005
CalQ45
I don't. That's nice of you. I just sent you an e-mail.
Raxephon
You've got mail.
[QUOTE=CalQ45] That's nice of you.QUOTE]
If you own a Datsun/Nissan/Infiniti I have to be.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
anlasak wrote:You've got mail.
CalQ45 wrote: That's nice of you.QUOTE]
YES, if your not nice we'll ban you!! Just kidding
Raxephon
CalQ45 wrote: Do I need to remove a cover over spark plugs first? I intend to replace spark plugs.
There are 3 bolts under the coilpack cover that you have to remove to take the VC off.
CalQ45 wrote:Should I replace the valve cover gasket first, and then spark plugs?
Thats optional. Eitherway is about the same level of difficulty for me.Just gotta be careful about not loosing anything down into the cylinder.
(Personally, anytime I dig into a motor, I like to prime it before I put the sparkplugs back in)
That would suck. I like it here.
