'94 q45 turns off
don
Car: 1994 Q45
it drives fine but when i stop at a light ect. it rev's down and up and stops running ive noteced the mufler puts while this hapens. after it dies on me im able to restart no problem it dosent do at every stop just every other.. help
5seryan
Car: 1995 Q45t R.I.P.
Welcome To NICO. do some searching around and read up a little. there is endless information on this type of subject so you have defiantely come to the right place. But from what i remember the 2 main culprits are the MAF and the fuel pump. Does it sound like an angry swarm of bees in your trunk? if so you most likely have a fuel pump problem. But search and read up anyways.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Or (all fiters fresh?), IAC or general intake path gradoo.
How many miles? Previous maintenance history?
Modified by maxnix at 8:08 AM 10/7/2005
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
5seryan wrote:Welcome To NICO. do some searching around and read up a little. there is endless information on this type of subject so you have defiantely come to the right place. But from what i remember the 2 main culprits are the MAF and the fuel pump. Does it sound like an angry swarm of bees in your trunk? if so you most likely have a fuel pump problem. But search and read up anyways.
I second that notion.. However, first check your MAF connector.. Wiggle the MAF connector at idle see if it changes anything...
Good advice, sean!
