94 Q45 Trottle body removal
CalQ45
Car: 1994 Infiniti Q45a
Need more specific instructions how to reach two allen screws on the bottom.
Modified by CalQ45 at 2:28 PM 10/7/2005
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You have to go buy a 6mm allen hex socket... You can get them at sears for like $3.. Its the ONLY way to get the bottom ones out...
edit, heres a quick picture of what they kinda look like
CalQ45
Thanks. Do I need to unscrew the front part first to access bottom screws?
Modified by CalQ45 at 5:03 PM 10/7/2005
elwesso
2007 BMW M Coupe
no... in fact unscrew them in a star pattern, so do one of the top ones, then its opposite bottom one, then theother bottom one, then the last top one...
To access the bottom screws, simply get your socket and put an extension on it. the other 2 screws are directly below the top 2 so you can kinda guess where they are. They have a little opening for yo uto put your tool in there.....
CalQ45
Thank you very much.
Modified by CalQ45 at 5:04 PM 10/7/2005
CalQ45
Sorry to bother you. I managed to unscrew a front lower screw. The other one gives me a problem. It seems life a front part (elbow pipe) is connected to a black metal bracket that holds vac hoses. Do I need to unscrew, or detached any major parts to get access to this lower screw? Do I need to detach accelerator linkage?
CalQ45
Is there any trick to remove lower hex screw close to the driver? I can feel the screw with my finger, but a long L shape 6mm allen wrench goes below my finger. The same with a socket wrench. Do I need to use "tilted drive" an a narrow one? Please help.
elwesso
2007 BMW M Coupe
Hmm, i never had any problem with it, it always went right in for me, even with my car with TCS....
CalQ45
Thanks for responding. I am still fighting with it usinf 1/4 " and 3/8" drives.Did it matter in your case? Did you ude "tilted" adapter?
CalQ45
I finally got if off, but only after removing this (however it's called) elbow duct in front of TB attached with three 5mm allens. Thanks for your help and responses. I will be removing plenum next.
elwesso
2007 BMW M Coupe
OH YES I completely forgot about that, of course you must remove that elbow thing. I just forget about those things because I dont have TCS on my current Q...
