94 Q45 tcs/slip light relays problem
apossiblehybrid
Car: 1994 Q45
So I've replaced the two relays with new ones as instructed in a thread about the tcs/slip relay for a 94 Q. The problem was solved for a couple weeks but then it goes back to throwing the tcs/slip lights and making the vibrating noise. This happens 90% of the time I'm using my car while the other 10% its normal. Can someone please help me out? Thanks.
Modified by apossiblehybrid at 4:20 PM 10/9/2009
Diesel6
Car: Infiniti Q45 2002
im having the same problem and my car does not go more than 25 mph...it just start to shake and stays at 25mph...check engine soon, TCS and SLIP lights up all the time now.
whats should i do?
apossiblehybrid
Car: 1994 Q45
Does anyone have any idea whats wrong?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Why not look in the service manual your car came with from the factory?
http://Nicoclub.com/FSM
Put the car on a dyno to perfom below test procedure:
apossiblehybrid
Car: 1994 Q45
i didnt find anything there and i dont have access to a dyno that's why.
Infinitiguy19
Depending on how much balls you got I would do this on a lift. Or someting that would require even more balls: Jacks.
The above picture is in the service manual.
