wrd0225 wrote:Hello. Sorry to but in, but my 90 Q45 is stuck in park. I tried the brake and can't get it out of park. How do I manually disengage it? I can't get the console out or the shifter handle off.
There is a button on the shifter assembly. It should have a sticker there that says "shift lock" but if not, it's just a button sticking up that you push down to get it to move out of park. As mentioned earlier in the thread, the shift lock has to "see" a brake pedal signal (from the brake light circuit) to release the shifter.
I'm guessing your sticker is missing - or the button isn't working - but this picture should help.
Good luck!
Heath
