94 Q45 stalls after reaching normal temp
myavar
Car: 1994 Infiniti Q45, 1996 Infiniti J30
The car will stall at cranking after it has been driven and sits for a while. I have to put one foot on the brake and give it gas while cranking up and then drive and it won't stall. Is it the Throttle Body that needs purging?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
check fuel pressure.... you have any symptoms of a bad fuel pump?
myavar
Thanks Wes. The car runs fine, problem is cranking after the car is driven and parked for a few hours. Sometime the check engine light comes on which I assume is to do with the EGR? It is random after I drive it 10-15 miles it might come on every now and then. If I turn the car off and then turn it back on; the light does not come on.
Any thoughts.
elwesso
2007 BMW M Coupe
check your ECU codes, thats the hint we may need.....
If its EGR its probably unrelated to the stalling issue, because if it was EGR related it SHOULD stall and run rough...
so let me ask you this: When you restart the car after it stalls, will it continue to stall, or will it start running OK again???
I need history on replacement of fuel pump and filter as well. do you hear any humming from the back seat area?
myavar
Wes: Once it cranks up it runs fine. I will check for the humming noise in the back to see if the fuel pump is working.
On another subject...Did all the 94 Q45's come with a CD changer in the trunk or was it an option?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
myavar wrote:Did all the 94 Q45's come with a CD changer in the trunk or was it an option?
Standard on t's and a's, optional on standard.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
My Q45t did not come with a changer in the trunk, but my standard Q did. Go figure!
elwesso
2007 BMW M Coupe
Yeah I dont think it was standard on T models, because my T didnt come with a CD changer (it has the dealer installed 6 cd)
