ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Wed Nov 22, 2006 6:44 pm
94 Q45 sometimes when the car is first started it will run very rough and you have to feather the gas to keep it from stalling, if I rev the engine white smoke will come out the tail pipe than change to grey looking smoke, If I shut the car off and restart it, it runs fine. flipping the bypass switch for the FPCM to high makes the engine stall.
I Swapped out the FPCM today with one from a 95 that had no burnt marks on the connector, started the car and it ran fine, wife took it out before shopping and told me it was doing what I said in first paragraph.
background info: new OEM fuel pump, new knock sensors and harness, new/used intake plenum (cleaned very well inside), new plugs, new PCV valve, cleaned throttle body and IAC valve, fuel filter not new but was replaced not to long before doing fuel pump. could use a new air filter but not terribly dirty. also ohmed the injectors all were with in specs
I know the car needs O2 sensors but haven't gotten to doing them yet.
Anyone have any ideas on this?? THANKS TONY
