Wecome to the most informative Nissan/Infiniti forum.Here's what alot of people on this board use. http://www.stillen.com/product...2890Ah ... ct...U2892blackeagle113089 wrote:I'm not sure what exactly it is that needs changing but I'm assuming the shocks. On the driver side front and rear, I jacked up the car and looked at the shocks, and I can see fluid leaking down the shock. I can also see it on my driveway from it leaking. The passenger side seems to be ok and isnt leaking. I'm assuming that is the active suspension fluid. What is it that needs to be replace, the shocks itself or what? I already know the price of shocks from the dealer isnt cheap at all...and ideas?
Do you have a Q45a? That is a whole different ball of wax. If you do, you need to speak with texasoil http://www.q45asuspension.comblackeagle113089 wrote:I'm assuming that is the active suspension fluid.
Nowhere does he state that he has the "a". I looked at his profile....maybe he forgot to include that LITTLE detail.maxnix wrote:Do you have a Q45a? That is a whole different ball of wax. If you do, you need to speak with texasoil http://www.q45asuspension.com
