moor2010 wrote:We have a 94 Q45 which will start, but idles rough and will not accelerate nor develop enough power to drive. Fuel pump and filter good, cleaned MAF and air filter, replaced pcv valve. Car also started leaking coolant from undetermined location at same time as accel/run problem started. College student son loves the car, would like to fix, but at what cost. Looking for ideas, we're going to have to tow to garage for lack of power.
Ron in Tucson
[email protected] or
[email protected]
First, do not tow, flat bed only.
Any intake path or maintenance history? Presume you have used OEM fuel pump and filter, O ring, tank was spotless, and fuel pressure on intial startup is at 34 psi?
Check the posts by AZHitman as there is a reference to a good independent shop in Phoenix. No known service providers knowledgeable of the VH45DE in Tuscon. It you have a trailer,
http://www.jerrytucker.net would be your best bet.
Welcome to NICO.
