steve94q45 wrote:...and my transmission fluid is blaaaaaaaaack, if i get a transmission flush will that make my acceleration and shifting better as well as idling?
A transmission flush isn't going to help with acceleration but it will help shift better.
Is the check engine light on? If so, have you puled the codes?
Before you replace all your injectors not a bad idea to ohm test them and the knock sensors.
Also check to see that the MAF connector is tight, clean of corrosion and coated in dielectric grease. They should all look like the middle pin. If you have corrosion on the MAF connector you probably have it on the CAS connector and the throttle position sensor and these should be cleaned, tightened and lubed also.
