94 Q45, preesure test hoses under intake plenum
ahardb0dy
Car: 1990 Nissan Sentra, 1994 Pathfinder Se, formerly owned: 2005 Nissan Titan, 1994 Infiniti Q45t, 1987 Nissan Hardbody SE-V6 4x4, 1980 Datsun 310GX
is there any way to pressure test the hoses under the intake plenum so I know they have a good seal before I re-install the plenum? can I use a radiator pressure tester to bring the pressure up to check for leaks? Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
yeah you could do that but i honestly wouldnt worry about it.. Just double check it , and then double check your double check... The way the coolant hoses work under the plenum (especially the big ones) is you shouldnt even have to have a clamp on them to stay sealed.....
What hoses are in question for you?
ahardb0dy
I was concerned about the 2 hoses and the connections where the coolant flows from one head to the other, I don't want to put everything back together than find out something is leaking.
When I put everything back together the first time after replacing the radiator, I left the rad. cap off when I started the car, took a few seconds before I realized coolant was spraying everywhere. The next day after work I saw coolant under the car, I checked the radiator connections but they are all dry, I think I didn't tighten the radiator petcock fully.
Than I noticed coolant in the valley under the plenum, I think that may have been there from when the rad. cap was off. I also found a hose that I must have left the clamp off, the one that goes from the "y" looking pipe up to the TB.
Well none of this matters for a while now that I have to find a new/used plenum after I cracked the stock one, it hasn't been a good week!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
ahardb0dy wrote:Well none of this matters for a while now that I have to find a new/used plenum after I cracked the stock one, it hasn't been a good week!!
Check out eBay. If there are none, I may have a link to one in Tacoma.
Also Pop Pop probably has one in Infiniti Parts Forum.
Q451990
Plenty of them on http://www.car-part.com - lowest priced 94+ is $60
They call it an "Intake Manifold" there...
Heath
ahardb0dy
Thanks, I have a line on 3 of them online already
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q451990 wrote:Plenty of them on http://www.car-part.com - lowest priced 94+ is $60Heath
Paid $5 plus $20 shipping for mine offf eBay.
