I do the exact same thing!! It's so much easier to run it under the car and if the amp is in the trunk then most trunks have holes in the trunk floor making it very easier to run it into the trunk. There's also a channel for other lines running from the back to front.T45 wrote:I have ran them under the car and utilizing existing grommets in the body before. Be sure to zip tie it to something other than the fuel line though. It keeps it out of the way and also away from your low level rca's or UTP's to keep engine noise to a minimum.
