94 Q45 power seat/doorlock switch cluster inop.
qsiguy
Car: 1994 Infiniti Q45 Turbo
The power seat/door lock control in the driver door is inoperative. Since I purchased the vehicle several years ago the problem was intermittant. The pass. seat controls are ok, the door locks lock if you manually lock the driver door, the locks work from the aftermarket alarm. The seat moves when inserting and removing the key. I assume that the controller in the driver door is defective but am hoping someone has some additional information on this problem. Anyone have a wiring schematic of the power seat/door lock system?
Thanks for any help.qsiguy
qsiguy
Anyone have any suggestions or wiring diagrams on this? I'm still having this trouble so I wanted to reopen this discussion to see if anyone can help.
Thanksqsiguy
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
qsiguy wrote:Anyone have any suggestions or wiring diagrams on this? I'm still having this trouble so I wanted to reopen this discussion to see if anyone can help.
Thanksqsiguy
Sure, download the FSM and all TSB from http://www.nisan-techinfo.com/infiniti/ for a one day subscription.
qsiguy
Old post but I wanted to close it out by letting anyone interested know that it's fixed. I found a seat/door lock combo switch for the drivers door on ebay and now everything works again! Nice and for only $29 + freight a real steal.
So if your seat moved forward and back when you put the key in or remove it but the door switches don't work for seat or door lock it's likely the switch in the door. FYI
Q451990
You do realize you're posting in a nearly 5 year dead thread...
Are you having a similar issue?
Heath
