Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Feb 19, 2007 4:44 am
120,000 miles is usually the start of the major rehabilitation period when hoses and seals and things start to need total replacement.
Where the shocks replaced at 60k, time again, same with upper links, tension rods, etc.
Watch out for alternator, ac compressor, knock sensors, plenum hoses, valve cover gaskets, etc.
Do proactive things to extend the life of transmission as that will cost $3-$4,000 to replace.
Do Anything and everything possible to reduce or defer the $6-$8,000 you will be spending over the next few years.
