Q451990 wrote:In two instances on my old Q I had spark plugs that were fouled badly after an injector failure - causing the misfire to persist even after replacing the injectors. I was able to clean or replace them and get everything up and running correctly again after that.
Yes this! That's the main reason why I just replaced all my plugs. Two of them were totally fouled beyond belief, from the two failed injectors. You should replace or at least remove and inspect /clean your plugs any time you have a injector(s) failure. It should really be mandatory.
Cylinder 1 and 2 plugs looked like Santa Clause's a** after sliding down 2 billion chimneys lol:
