94 q45 low and rough idle
MACUSER
I have a 1994 q45 that has a low idle around 450 in drive and 500 in park .idle is rough. smooths out out with my foot on the gas around 750 or 1000 still tiny bit rough . drives great though responsive not sluggish . also has a slightly hard shift from 1st to 2nd . Any help would be great . thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Welcome to our club, MacUser.
But we will need a little more maintenance history to help.
What intake plumbing has been cleaned recently? Injector maitenence? Fuel filter and fuel pump?
What is your transmission maintenence history? How does the ATF appear - white paper towel test?
Mileage? Driving regimen?
MACUSER
Just bought the car a couple days ago i do have the reciepts from when it was new all work done at the dealer.What intake plumbing has been cleaned recently? None that I know of
Injector maitenence? dealer used bk44 i think it is a couple years ago has had 3 injectors replaced Fuel filter and fuel pump? not sure
What is your transmission maintenence history? has 3 fluid changes and a flush done athe the dealer last one was about 25,ooo miles ago
How does the ATF appear - white paper towel test? what is this test
Mileage? 118,000Driving regimen? city and high way
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
MACUSER wrote:1.) Just bought the car a couple days ago i do have the reciepts from when it was new all work done at the dealer.What intake plumbing has been cleaned recently? None that I know of
2.) How does the ATF appear - white paper towel test? what is this test
1.) Get the Infiniti dealer performed service history by submitting the VIN to yur service writer at your dealer. Tell them you need to budget for upcoming maintenenance. You can get an oral version by doing the same thing at Infiniti customer service when you register your vehicle.
2.) Grab a can of the same brand ATF in your car and compare the color of the new fluid to the existing fluid. Discoloration is a good indicator of wear.
Do you have an auxiliary cooler? probably good for the summer but maybe not for the winter if you drive in subzero weather.
At 25K, might well be time for another mechanical ATF exchange, pandrop, and filter replacement.
http://www.bgfindashop.com will give you an idea of BG shops in your area. Call first to check on services offered as some don't do the pan drop and filter replacement.
MACUSER
What about the low and rough idle..thanks
