94 Q45 Liquid-Filled Bushings between body and frame
off2sobe
Car: '94Q TCS, original transmission @ 230,000 miles
1994 Q45-- How do you replace the liquid-filled bushings between the body and the frame? I have one that has busted (left rear). Are there 4 total?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No one has yet found a replacement except for polyurethane like in the Z32 subframe.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Thats how you want to replace them. Everyone has said that the poly dont add any sort of vibrations and really tighten the rear end up.. no more wheel hop!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote: Everyone has said that the poly .... really tighten the rear end up.. no more wheel hop!
How would polyurethane bushings vs. OEM silicon filled rubber bushings on the rear subframe affect wheel hop?
elwesso
2007 BMW M Coupe
Less play in the rear subframe.....
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
check out suspension technology for the poly bushings also get the bushings for the rear end best suspension upgrade i have done the other option is replacing the entire rear crossmember
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Less play in the rear subframe.....
Than OEM? I don't think that would affect wheel hop at all.
It is more a function of springs, damping and coeffcient of friction of the tires. Subframe location will be fundamentally the same regardless of type of bushings employed.
off2sobe
So....has anyone actually changed them out? If so, can you describe the process?
elwesso
2007 BMW M Coupe
Have you done a search... mark86T did an EXCELLENT writeup!!!
Theres also one as a sticky in the suspension forum, for a 240 but its just the same.
