off2sobe »
https://forums.nicoclub.com/off2sobe-u22827.html
Tue Apr 26, 2005 6:53 pm
Maxnix, you either have not pulled a Q plenum or you did not understand my question.
I would like a definitive answer regarding the use of a KS harness designed for a non-TCS Q can be used in a TCS Q (since it was just installed Sunday) by doing one of the following:
1. Change the coolant temp sensor to a non-TCS sensor. (If they function the same, this is a no-brainer).
2. If the sensors function differently (yet to be determined), can we splice a CTS plug from a TCS Q harness to the new (installed, yet incorrect) non-TCS Q harness.
Both harnesses are identical, down to the wire coloring, except for the CTS plug.
