sjava wrote: Couple of questions: I assume I should lubricate the injector O-rings during installation, any specific lubricant? With the new valve cover gasket should I add any silicon sealent?
Here's a good thread put together by one of our gurus, Jeff Williams. It looks like you do need to RTV the CAS but since you have a 94 the valve cover gaket is OK as is. 90-93 have no gasket and use RTV only.
zerothread?id=107690
For torqueing the FSM may show the torque pattern. You can download it free at phat.g20.net. (I've got a hard copy for sale in the classifieds if you need one). If the FSM doesn't specify start in the middle and work your way to the outside, alternating top and bottom in a criss-cross pattern.
Lube those injector o-rings up heavy with vaseline. Make sure the fuel rail grooves are good and clean. They'll plop right in and any excess vaseline will burn off before your engine warms up. Good luck.
