94 Q45 help!
Cali-Q
my "automatic drive positioner" does not function! i replaced my fuel pump, fuel filter, water pump, etc... so anyway i pulled off the negative terminal plug from the battery to safely work on the car. i get done working on the car, start it up and the automatic drive positioner stops working. when i slip my key in the ignition the seat nor the steering wheel does not move. i can still adjust them but it wont pull in and out automatically for easy access in and out of the car. what could be wrong? i know about the cancel switch and it does nothing when i turn it on or off. any help would be appreciated.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
You lost your settings when you disconnected the battery. Just reset the positions and you should be back in business.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
You might need to reset the settings. There are a few threads about this, but the gist of it is this:
insert the key, shut the door, turn the ignition on, turn the key off, and leave it in the switch. Open th edriver's door, then close it. wait about 2 to 3 minutes, then open the door. The steering wheel and seat should then move to teh exit position.
