sandcobra wrote:I bought a set of Tokico (blue) from motorsports direct straight off E-bay. The prices were very good and service (shipping) only took a couple of days. Be prepared to install new bump stops on the front. Mine were totally shot. Got those from Advanced Auto store (Moog parts). No major problem to change out struts if you have a spring compressor. The biggest hassle is getting the trunk carpet trim loose so you can get to the upper rear strut mounts.
To add to the trunk part, DO NOT drop the upper mount to shock tower bolts. If you drop them, they will fall under/around the gas tank and will be lost. When I pulled off the carpet trim, the first thing that came to mind was, "don't drop the bolts!". I pooped bricks when I did drop one but luckily, it fell in plain sight. I was extra careful after that.
