Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Feb 27, 2007 3:56 am
Shocks are FAILED long before they leak, shocks last at best 4-6 years and no more than 60,000 miles before they are significantly weaker than new.
Histoically the rear start to go first with an mild undulating bobbing up and down motion on a smooth interstate..............feeling the springs cycle.
Tire radial force and misbalancing plus rotor warpage are additive and vary with temperature. As you turn the tire wheels, rotors get out of phase and the imbalance move around relative to each side.
Often the rotors will need retruing every 6-8,000 miles to achieve perfection, this is before you feel a vibration when braking........a little of each error can be additive.
Start with premium Michelin tires, on tested and perfect wheels, then true rotors to better than oem spec and you will have a ride you never dreamed possible if all suspension components are as brand new.
The above is expensive to maintain since things wear and go out of spec so fast because of the weight of vehicle.............things were made too flimsy to save weight.
Upper links last 30k nefore they get loose and sloppy, tension rods, bushings, suspension arms and mounts bend....................a never ending nightmare to maintain as new.
People standards and pocket books vary as to whether they are willing to spend $3,000 or $4,000 per year to achieve perfection.
