94 q45 Factory Audio Questions
SunnyTk
Car: 2003 Nissan Pathfinder
Soo I wanted to upgrade the speakers and head-unit on my 94 q45. It has the Bose system with 10disc cd changer (not sure if thats an option). Soo I took apart my drivers door to see exactly what size the front speakers are since I couldnt find any info on speaker size. I took out the 5.25" midrange speaker from the panel and noticed a little amp/box behind it. I assume it is a sort of crossover, and if it is, would I be able to keep it? I assume the rear speakers are 6x9"s
SOO, my questions are,
What is that box behind the front speakers in the doors?
Where is the bose amp?
How do I bypass the bose amp without running all new speakers wires to each speaker?
Where do I find a CORRECT wiring harness for an aftermaket Double din head unit that allows me to use my cd changer?
How do I remove the A-pillar to get to the tweeters?
thanks in advance :crazy: :)
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Here are some threads you might be interested in reading to help get you started:
Interesting find about the early G50's audio system
post4246291.html
Anyone use Crutchfield supplied parts to replace 94-96 stereo headunit?
post2986191.html
Upgrading OEM Stock Bose Stereo Speakers etc
post1972423.html
Are all G50 Q45 speakers and amps the same?
post5678060.html
Aftermarket speakers in the front doors of a 94 Q
post5315236.html
G50 door speakers
post2405927.html
1994-1996 Q45 Tweeters on a 1990-1993 Q45
1994-1996-q45-tweeters-on-a-1990-1993-q45-t431520.html
