3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Fri Jan 27, 2006 6:12 pm
you are saying the '94 is an active suspension? the PS pump is different, so you'll need the '91 ps pump. but then you'll also need the 91 crank pulley and wp pulley to match. then, you'll also find that the wp snout dimensions are different on 90-93 from 94.
iif it were me, i'd get a new 91 wp to fit on your 94 block, swap the crank pulleys and change out your front seal while the pulley is off.
