Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Thu Jan 04, 2007 4:20 pm
It is probably something in a bind in the linkage.
Another idea, is a loose wire. Layla did this periodically. I could press against the passenger arm rest or slam the door, and the doors would lock, then unlock, then lock. When I was unlocking the doors with the remote, it would unlock, then immediately lock again.
If I took the door apart, and re-set all the wiring connections, it would work fine for a few months, then start to act up again.
Lola looses communication to the driver's door LAN moudle periodically, and the seatback stops working, and the easy access quits. I have to unplug the module and wiggle the wires, then reset the battery, and she is fine for a few months. One day, I will have the time to check the connectors, but until then, I will just keep doing the quick fix.
