94 Q45, 153K miles. All original.Recent spark plug change.
My condenser fan for the AC is not blowing at all, even when the temp is really hot. When I come to stop light, the A/C compressor switches off. I have tracked the problem to the cond fan, which is not circulating air over the condenser, so the high side switch cuts the compressor off, which leads to hot air blowing.I checked the fan separately, and when I put a 12V supply to it directly it runs fine. I have replaced the solenoid(with a known good one) in the fuse block under the hood. I also checked the fuse for the cond fan under the hood.I have also check my shop manual, but can find nothing on how to troubleshoot this.Any ideas?
