scct40 »
https://forums.nicoclub.com/scct40-u29977.html
Fri Jun 24, 2005 3:10 am
I just replaced my rotors,calipers and pads. The car sat for a few days so all the brake fluid drained out. I followed the fsm procedure for bleeding,starting with the master cylinder,repeated this 3 times. Pedal still goes to the floor when running. I read the previous posts and someone mentioned bleeding the abs actuator. Not sure how you would do this and its not mentioned in the fsm. Any advice would be welcome.
