bspake wrote:The code results are 34 Knock Sensor & 51 Open Injector Circuit code. I spoke to the local Houston Infiniti dealer and he said replace all 8 injectors and both knock sensors......
At this point follow Maxnix's advice and ohm your injectors. Don't take it to the stealership to have it done because they're going to tell you to replace all 8 and the cost could very well reach as high as $5000 (qship is right) once they have you in their grasp with the plenum off your engine.
If you don't own a voltmeter go buy one for $10-$20 at Radio Shack, Best Buy, etc. Ohming your injectors is simple. If you have 10 minutes and don't like getting your hands dirty this test is for you.
With the engine and key off, the meter set to ohms resistance, and the positive probe of the meter to the positive post of the battery, measure the resistance at each of the 8 pins on the connector and record the reading. My guess is you have at least 1 or 2 injectors reading above 14.0. The connectors are located on the passenger side end of the plenum and you may as well measure the knock sensors while you're there. Let us know what you find and we can go from there.
