The CEL you describe sounds like o2's, but you have tro stop running 87. Bad things will happen if you do not run premium all the time. They may not habppen today, they may not happen next month, but they will happen.kevinpaigeking wrote:it runs good. plenty of power. Idle is not perfectly smooth. Also, check engine light will come on after extended driving, but does not stay on. Lastly, every so often the car will have abrupt loss of power for a micro second. this never continues after 2 or 3 hiccups.I was running 87 fuel when i had it smogged. will 92 really make such a difference? What about my O2 sensor?
It certainly can/will. As soon as the ECU see's a knock code it switches the knock maps (fuel and timing) which are very different. If the emissions place does the "dyno" test it will most likely fail. I was not running low octane. I always run 91 (best we have unless you buy race fuel which I do occasionally). All I had to do to pass was bypass the faulty knock sensor with a resistor and it passed with flying colors.texasoil wrote:...KS will not effect emissions unless you are running cheap low octane fuel--and if you are, it will probably never pass the emissions test...
Kevin, have you determined what code is triggering the CEL? BTW the knock code will not trigger the dash CEL.
A new knock sensor is about 500-600K ohms. Check your current sensors and determine which one (maybe both) are bad. My bad one would measure all over the place depending on engine temp. I saw readings from around normal all the way up to 25M ohms. I clipped the knock sensor input near the ECU and wired a 560K ohm resistor from the ECU sensor input to ground. You could also wire this up out near the plenum. Just make sure the wire coming from the sensor is not still wired up with the bypass resistor.trajanH wrote:How did you wire a resistor to bypass the knock sensor? I would really like to know that cause I have a knock sensor code triggering and that part seems almost impossible to replace on my Q. Thanks.
Actually, that should be ever. Emergency use only, small quantity, and replace ASAP with Tier 1 Premium.elwesso wrote:Also, what makes you think its a good idea to run 87 octane, especially when going for an emissions test??????
