BS (I shortened your name ),
First, welcome to NICO, the BEST forum there is on the Q45. There are a couple threads you can search the archives on a lot of issues. One forum is the Infiniti Online Mechanic, the other is the VH/VK thread. Infiniti General used to have all of us in it, until the Q45 thread was started.
Now, to your problem...
I hope you used NGK plugs, and the correct ones. If not, buy a set, & get them replaced. I used to use Bosch platinums, but the VH45 will burn them up on the highway. It can really hurt your power.
Next, make sure the fuel filter is new and the Air fliter is new. You probably already did this.
Make sure the throttle body is spotless. Use a compelte can of spray cleaner on it. The car will be hard to start afterwards.
Another issue could be the fuel pump going bad. Check the back seat while the engine is running, to see if you hear the angry bee buzz from the fuel tank. It is an easy fix ($300 in parts, about 2 hours tech).
Then, check the codes on the ECU. There are a few threads about this.
The first thing I though of was the knock sensors. If they are reading a failure, you can reset them, then see if the failure comes back (90% chance that is what it is).
When the knock sensors fail, the ECU can limit the timing advance, and KILL the power. The sensors are deep under the plenum (6 to 12 hours tech, $300 to $800 in parts depending on what you replace). You should replace the vacuum lines, fuel lines, and all hoses under the plenum, replace the harness to the knock sensors, and take a hard look at the injectors. Spend some time cleaning the fuel rail and upper and lower intake runners.
I thought my pup cats were plugged on Lola, but when I gutted them, and replaced the exhaust, there was little difference in overall power and performance.
Initial timing can be off.
Check your EGR and IAC valve for proper operation.
If you need a field service manual, shoot me an email with your address, and I will send you one. If you have PayPal, send me a couple bucks for the postage and CD.
[email protected]
Good luck!
I have spent over $6,000 on Lola trying to get her back to original factory condition and improve performance. And all of this does not include labor. It is definitely a love/hate relationship.
