94 Q transmission swap
Black stallion
Car: 1994 Infiniti Q45
2006 Infiniti QX56
Ok after looking at my situation I've decided to drop another trans in instead of rebuild...Question is (after 2 days of searching) which trans are interchangeable? Is it 89-93 then 94-95 or is it a wider range or narrower? What year should look for/avoid for a '94?
qship96
Car: 1996 Infiniti Q45
Why not just call joe at Scottsdale Infiniti and order the correct one?
I wonder if driving the car without the transmission filter O-ring in place is what destroyed your transmission at such low mileage?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:I wonder if driving the car without the transmission filter O-ring in place is what destroyed your transmission at such low mileage?
What?
The best and ultimately cheapest deal is to get the Nissan remanufactured one from Joe, unless you love repeated labor.
Black stallion
2006 Infiniti QX56
Just out of curiosity, what does an Infiniti reman'd transmission run? and with what type warranty
Q45tech
In this case the warranty is meaningless since on the last 30 or so we've used as replacements zero failures have occurred in 70,000 miles.
I have one on my Q with 118,000 miles replaced in 2002.
AS with all Parts, Nissan gives an offical 12,000 mile 12 mo warranty.
Around $3,100 with shipping [core return] and labor is an average independent price.
Whatch out for low quality chain store/shop rebuilds they won't last and half the expensive parts are skipped [new TC and Japan renovated valve body].
fixer
Car: 08 Sentra
i have had good luck with rebuilders in the area who reman these trans, but on the other hand we have never had a come back with a factory reman. our rip-off price is around 4500. but i am at the only dealer in Las vegas
