'94 Q transmission question.
cabal1024
Car: 2005 Q45
It seems that I have WAY too much fluid in the transmission; hot or cold. It is always about 1 inch above the hot max mark. I drained about 2 quarts and it still looks high. What is the deal?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Are you sure it's not too low and foaming?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you are checking it with the engine running in park, right?
q45VIP
Car: 94' Q45t
I got the same problem .Except mine is leaking it from somewhere.I thought it was cause I over-filled. I washed the undercarriage to see if I could tell where it was coming from but, no luck.
I check it when its warm and running and it shows its got more then it should.
cabal1024
Car: 2005 Q45
Yes, I am checking it correctly, and no I don't know if it is foaming... Doesn't look foamy.
