If subpar short term performance is tolerable and you have lots of time and don't mind repeated labor, it's a great deal. If you want to enjoy your car and life ingeneral, much more expedient to install the Nissan reamnufactured one from Joe.breaksr wrote: I can get the transmission and TCU for $250 which I thought was a decent deal.
This is true, hence my caution on the ATF condition as a tell tale. White paper towel test must be performed.qship96 wrote:Engine overheat, especially one severe enough to destroy the engine, almost guarantees the transmission also overheated......as the 94-96 dual IN- RADIATOR HEAT EXCHANGERS and thermal coupling of metal transmission case bolted to engine block transfers heat extremely well.
An overheated transmission suffers similar, if not worse decay, as the engine- seals warp and distort, varnish forms from boiled atf,etc
The engines destruction from overheating is a HUGE RED FLAG as to transmissions health!!!!!!!!!
You may get lucky and have no problem with this transmission, but good to know the possibilities before you lay down your cash for the part and especially the labor costs!!!! Now you have more info to decide if you want to take a chance on it or not- If you are doing the labor yourself, and seller offers you a 30 day money-back guarantee on the part, it might be worth rolling the dice and trying it?breaksr wrote:Okay did not realize that the overheat would have such adverse affects on the transmission. I was told motor would still work but not all cylinders had proper compression so parting the car out seemed more financially practical.
Spoken by one who knows.BadQ45t wrote:This sounds like a complete waste of time and money.
So 1 year and out or 5 more years, that is really your choice since this transmission is already at 150k that means maybe 50k miles and a rebuild/replacement is in order again.
